1 - 4 of 4 Posts
Hey All,
I noticed most of the Angel Eye kits for the non-HID headlights come with two 145mm rings, and two 131mm rings. The 145mm rings match the outer diameter of the headlight buckets on both high and low beams.
Are the 131mm rings supposed to go on the low beam buckets, or the high beam buckets?
Thanks,
Dan B
Discussion Starter #3
Good to know.
(I have a pre-facelift model). no projectors (yet) - just the stock buckets. I was leaning in that direction - If I use the larger rings on the high beam buckets, the shroud will cover a good portion of the bottom of the rings...
Thanks!
Dan B
1 - 4 of 4 Posts
