1 - 4 of 4 Posts
I have one side of my Angel Eyes out. Can anyone suggest the best methode to troubleshoot? They were installed in the car when I bought it so I'm kind of lost as where to begin. Thanks.
The first thing I would check is the ground going out from the inverter (ballast) of the not-working side. On mine it's a brown wire (not sure with yours). Make sure that it's securely connected to a grounded spot.
If that doesn't work, try to unhook the power inverter (ballast) from the working side, and plug the wires from the non-working rings into that inverter. If they light up, you figure you either have a bad ground or a busted inverter. If they don't light up, you might want to come back or call their customer support.
Discussion Starter #3
I believe that the problem is the ignightor ballast box. Problem is I have no idea who made these angel eyes since they were already installed when i bought the car. Any idea how I might be able to tell who made them so I can run down a replacement part? There are no markings on the ballast box itself.
Thanks.
I'm not too sure about how to tell who made them. Might want to post pictures of the rings and the inverter/ballasts. I remember seeing a link a while ago of an inverter that fits angel eyes perfectly, not sure though, might want to look around for that.
1 - 4 of 4 Posts
