1 - 6 of 6 Posts
Hi All,
My the inverter that came with my wiring harness for my angel eyes went (3 months after I bought it) and I have been sent a replacement inverter from the supplier.
The problem is that the new inverter the supplier sent me is different then the one that came in the kit. I tried to wire this up in my original wiring harness and it is not working at all; the connections to the angel eyes are different. And the supplier is being NO help.
I can figure out that the red is power, brown is ground and the white leads are for the angel eyes but what do I do with the switch wire that goes to my ECU box, there is no place for it in the new inverter.
Ive looked at a couple of DIY's but none go into specific instructions for wiring this inverter.
Thanks in advance for the help.
The pic on the left is Inverter the Pic on the right is a relay....
Discussion Starter #5
I am able to remove the lens cover to install the inverter but I cannot access it because the headlight units are in the way.
How do you access the inverter on the P46s once the lens cover is off?
1 - 6 of 6 Posts
