Going further down the M brake duct rabbit hole...
For sedans/wagons each duct assembly is made up of a tube, and a bracket. There is a standard non M tube for standard bumpers (EDIT: and the standard tube is also used on Mtech I bumpers), and there is an M tube for and Mtech II bumpers. There are various different brackets that can be attached to the tube to make up the other half of the duct assembly. The bracket shape is what determines if it will fit a RWD or AWD car, etc.
The RH side duct is the simplest example. There is only one M version of the tube, but it can be attached to two different brackets to either turn it into PN 7894700 for RWD, or 7894706 for AWD.
The tube itself is stamped with both part numbers (kind of hard to see in this cropped/rotated photo).
The same is true for the LH side M tube, which can be used to make a handful of part numbers, depending on what bracket it's mated to, and if it was molded with or without the oval alternator duct cutout.
Anyway, my point is that it looks like one could theoretically piece together a correct set of ducts using various tubes and brackets without having to spend $750.
