Went exact same route with mine 💪Photos at 101 above.. I have removed the small screws and am red locktighting them in, on brush cleaning the inside recovered some fine metal dust, will be using OEM gaskets, so far so good.
Honestly.. I had used the supplied gaskets on my first valve cover. And not for nothing. It held up fine. None of the grommets leaked no the valve cover gasket, for the time I did have it on 😂 until I spotted that dreaded tiny fracture 😩honestly I could’ve probably fixed it but why should I have to paying what I paid for it.idk why I just need things to be perfect lol…but it was only after that and gettin the replacement and installing it that I used a different Valve cover gasket and grommetsG'day all,
although I have purchased a REIN valve cover rubber gasket set I'm wondering if anyone has used the supplied rubber gaskets and what was the outcome?
Thank you very much for your comment, I recon I'm as fussy as you are .Honestly.. I had used the supplied gaskets on my first valve cover. And not for nothing. It held up fine. None of the grommets leaked no the valve cover gasket, for the time I did have it on 😂 until I spotted that dreaded tiny fracture 😩honestly I could’ve probably fixed it but why should I have to paying what I paid for it.idk why I just need things to be perfect lol…but it was only after that and gettin the replacement and installing it that I used a different Valve cover gasket and grommets
AgreedLooks good. Your CCV hose at the valve cover appears to be missing the clip. May want to address that before too long.
Amazon claims they have 14 in stock.And it seems to be out of stock everywhere
Yes the latter type, I should have been clear.Amazon claims they have 14 in stock.
https://www.amazon.com/dp/B09NVLK49Z/
Have they reported back? I am towards the middle of this project, waiting on new bolts... whoever did previous work did not replace 2 of the bolts to the valve cover with original type or size, so I ordered them and will clean the ICV while waiting...... sigh*Cracked and seeping plastic valve covers are common at this age and number of times removed/replaced.
It seems there is now a chinesium aluminum replacement.
A guinea pig has purchased one and will report back. 🐷
