After watching 50skid doing, what was to be, a voltage regulator replacement for his alternator, on the way to my moms house my battery light comes on. Makure sure all lights are not used, not AC, no fan, and use signals as little as possible I made it to her house and back. At the end the brake and ABS lights came one especially when I used the turn signals.
Used the battery test in the dash cluster and I see 1a bit over 11v (most likely due to driving on it) and a drop to 10v when I started the car.
Battery is just less than 2 years old (Oct 2019) and I drive it 100 miles/day for work so very few short trips.
Seems to be 2 possibilities at REALOEM:
Any way to know which one of these were original to the car? I assume it was 12317501690...?
The drop points to an alternator issue and most likely a voltage regulator but as far as I know - it is the original alternator so it is nearly 20 years old and 287,200 miles on it (Bosch AL0703X - this seems to suggest it is not original though - had to have been replaced before me - before 150K miles) I plan on just switching out the alternator due to its age and I know power steering fluid got dripped in it for awhile.
Does the diagnosis seem sound?
