1 - 20 of 32 Posts
Hi mates,
I thought about opening a place where everyone can post deadtimes / lagtimes and general data about suitable fuel injectors for (forced induction) engine builts.
Even though the Siemens MSxx ECUs are like an open book now, there is no collection with different possibilities for going the FI road.
Please include the following values when posting injector data:
Manufacturer:
Model No.:
Donor Vehicle:
Flow And Pressure: in cc/m and bar/psi
Remarks: (direct fit or adapter needed?)
Minimum Injection Time: in ms
Deadtimes:
  • 0V -
  • 6V -
  • 8V -
  • 10V -
  • 12V -
  • 14V -
  • 16V -
  • 25V -
Let's make this the ultimate place for fuel injectors :thumbsup:
Discussion Starter #2 (Edited)
Manufacturer: Bosch
Model No.: 0280158123
Donor Vehicle: Porsche 997 GT2(-RS)
Flow And Pressure: 627cc/m @ 3.0bar
Remarks: direct fit
Minimum Injection Time: 0,499ms
Deadtimes:
0V - 2.94ms
6V - 2.94ms
8V - 2.94ms
10V - 1.58ms
12V - 1.15ms
14V - 0.73ms
16V - 0.55ms
25V - 0.55ms
Help on filling this:
Manufacturer: Siemens Deka
Model No.: 6900371
Donor Vehicle: Volvo s40 T4 (1.9 Turbo)
Flow And Pressure: 440cc/m @ 3.0bar
Remarks: direct fit
Minimum Injection Time: ...
Deadtimes:
0V - ...
6V - -
8V - ...
10V - ....
12V - ...
14V - ...
16V - ...
25V - ...
Model No.: 6900371
Remarks: direct fit
Deadtimes:
0V - ...
6V - -
8V - ...
10V - ....
12V - ...
14V - ...
16V - ...
25V - ...
I have measured them in car with 1,5 x Flow of the stock b30 Injectors.
Dead times posted by rb01:
4.44
4.44
1.88
1.15
0.94
0.85
0.77
0.04
The 42lb/hr Bosch "green giant" is a popular choice. Fits the fuel rail and EV1 electrical connectors perfectly. I can't speak to whether they are too tall or not on the stock manifold, but they fit perfectly with the ESS twin screw supercharger kits.
Spec sheet is attached.
Any of you guys using the Siemens Deka 6900371 on the stock M54 intake manifold? I'm curious about the injector's spray angle, if there is any at all.
On the M54, BMW had injectors made with a 25 degree spray angle to point the fuel directly at the back of the intake valves.
When you put an aftermarket injector into the M54B30 intake manifold, it sprays fuel at the port floor, not at the back of the intake valves. This makes tuning part throttle tip-in, and even idle very difficult.
Model No.: 6900371
Remarks: direct fit
Minimum Injection Time: 0.485ms
Deadtimes:
0V - 4.44ms
6V - 4.44ms
8V - 1.88ms
10V - 1.15ms
12V - 0.77ms
14V - 0.51ms
16V - 0.34ms
25V - 0.04ms
Leonardo how did you came up with these dead times, since they are a little different than rb01's posted above.
Also how are these injectors working for you overall? Do they have a spray angle similar to the stock ones or they stray straight down?
They were provide by a user member - sda2 -
Ahh too late ive bought them a while ago... what problems did you have?
Lean codes on some rebuilt ones from trying to be the cheap bastard that I like to be. Then I had some non VDO ones, can't remember the brand, sorry, but my ass told me I wasn't getting way top end power. Finally laid out my dough for the VDO ones and I've got the progressive power build all the way to the top now
Sent from my VS988 using E46Fanatics mobile app
Which VDO injectors did you end up with?
I've tried Bosch and Siemens DEKA injectors both with extended noozles, they worked fine at high revs but they are not smooth down at 1-2K RPM.
Because Race...Convertible?
Turbo ZHP Convertible
Green giants are good but not suitable for E85. 123 are expensive. I am using a version of the 123 common in Fords, the 298. Ill post the latencies I extrapolated but I did rescale the voltage from 10 to 17v I believe
Manufacturer: Bosch
Remarks: direct fit
Deadtimes:
0V - 2.94ms
6V - 2.94ms
8V - 2.94ms
10V - 1.58ms
12V - 1.15ms
14V - 0.73ms
16V - 0.55ms
25V - 0.55ms
I have a Brand New set FS if anyone looking
I've got a question about injector scaling. I am going turbo and started the tuning process to learn. I have Bosch green giants that are listed on the wiki. I have the spreadsheet with all the values needed but they are rated for 39.15psi. I know the stock fuel pressure is 50.76psi so do I divide 50.76 by 39.15 to get 1.296 and then divide or multiply every value in the spreadsheet by 1.296? I realized that it may cause issue for others thinking you can just plug in the numbers from the wiki. Thanks in advance.
I also did maf scaling using the PMAS transfer function tool. I only edited ID_MAF_TAB. Is there anything else I need to edit? I modified both x and y value axis to match the excel spreadsheet exactly. I set the multiplier in the excel spreadsheet to 0.944 so that the voltage and airflow is corrected to a max limit of 2048 kg/hr.
Does anybody know about Bosh 0 280 155 759? Was used on 1.8 turbo Volvo and was installed to some of ESS kits(m54b30).
Just know - 330cc at 3.0 bar
Bosch EV6CL fuel injector
Long size injector
Jetronic port
4 hole nozzle
Conical spray pattern
Flow rates @ 43.5 psi / 3 bar
31.4 lb per hour
237 G per min. (N-Heptane)
330 cc per min
15.95 Ohm resistance
100% fit to m54b30
Maybe somebody have settings? I am interested because current injectors is very cheap!
1 - 20 of 32 Posts
