1 - 3 of 3 Posts
2000 323Ci- just had tires balanced tech said one of my rims is bent, and he said i needed 4 wheel alignment, because of uneven wear (cupping) all around and he said the alignment was causing separation (knots), so i had the car aligned and now the tires are noisy, will this fade as the wear pattern changes or am i stuck.
Any time you change the alignment, you change the way the tire meets the road. This should go away in time as the tires take a new set.
1 - 3 of 3 Posts
