Hello,
Airbag light came on randomly while driving, I have a B800 airbag reader/reset tool that reads Table 10 error 06 "Firing circuit, side airbag, front right side" . When trying to clear the light, it turns off for a second then immediately turns back on.
I took the door panel off, got a connector from the junkyard (protip: 2001 side airbag connectors are different than future iterations, no release clip) - and read the resistance of the airbag (seems normal about 2.5ohms) - also picked up an airbag bypass resistor for 10$, no luck with that
Visually the wires in the door look ok (from what I can see in door panel)
MY MAIN QUESTION (that I can't seem to find anyone talking about despite searching) is about checking the wire running through the door. I'm a bit hesitant to start poking with it for fear of setting off other airbags somehow.
Should I poke a multimeter in there? Check for continuity? Check for resistance? What sort of signal should be pumping through those wires?
