So, I'm debating on which one to get. Between the 2 AFE which I been doing a lot of search online and haven't found a comparing between this 3. What would you recommend? Getting the Performance OEM , aFe Stage 1 Cold Air Intake System Type Cx or the Suppostly new aFe Power Magnum FORCE Air Intake System . I said suppostly new because It seems like it's been out a while yet I haven't found any information about it as people who have them. I have read that the "aFe Power Magnum FORCE Air Intake" seems to have marginally better HP gain. Stage 1 has the integrated cover design.
The aFe Stage 1 Cold Air Intake System Type Cx is better with the Pro Dry S which is a dry air filter so no oil is used. The filter is made of 2-layer synthetic material and can be cleaned with a house vacuum and/or soup and water and reused, thus it is marketed as a lifetime filter.
First look, the Pro Dry S seems to be well built. It is quite a bit smaller than the OEM Mann filter and the pleats are quite shorter as well. The number of pleats are fewer so they look far apart than those on the Mann filter.
http://www.modbargains.com/aFe-Stage-1-Cold-Air-Intake-BMW-E46-3-Series.htm
Then there is the aFe Power Magnum FORCE Air Intake System Which I don't know anything about.
So far it states:
This Stage 2 Intake produces 6hp and 12lbs. x ft. torque. It incorporates a unique coupling that smoothes air transition into the intake tract for better performance. The one piece heat shield features an integrated clip to allow for minimal assembly and provides a direct bolt on fitment to the factory air duct. The filter is constructed with 100% polyurethane for long life and multiple cleaning cycles.
http://forum.e46fanatics.com/showthread.php?t=879523
Last we have the Performance BMW OEM
Which people says "Replacing the entire air box system, this intake flows better than stock, freeing up hidden horsepower. With a stylish design and carbon fiber accents, BMW Performance is inscribed on the top."
http://www.ecstuning.com/BMW-E46-325i-M54_2.5l/Engine/Intake/ES35343/
Which one will you recommend???
So far it states:
