you seem to be switched on with A/C problems
You need to use a pwm fan control that allows the dme to control the fan. Get rid of the flexalite control that probably just has a temp probe in the radiator. Bmws fan control is far superior to any little aftermarket box. If your original fan has the separate control (early version had it integrated with the motor) you can use that to control your aftermarket electric fan. Unfortunately if the original fan fails it's usually the speed controller that fails but it seems that you are trying to upgrade cooling so maybe your original fan works? Is it manual or auto transmission? There are other makes and models that have compatible fan controllers that can be found used (junkyard or ebay) but I don't remember the exact vehicles. There are threads about replacing the fan controller (not available separately) or you can install a puller fan from a manual transmission car if you have a belt driven fan and want to eliminate it.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Hi Randy maybe you may be able to help..I have 2002 323i Msport and yes that is correct 323i Auto "with tiptronic gear change" ..cause they were still being delivered to Thailand ...I checked the A/C with manifold gauges and the system read 32LP and 140HP,.lost a bit of gas when I disconnected gauges mostly from HP port
Problem is A/C Aux fan ...A/C cut out and I took it to a so called mechanic who added a bit of gas ..he only hooked up LP side and gauge read about 20+psi so he charged it to 31psi ..system worked for a few hours but just started blowing hot air .I noticed when he hooked up the yellow port he did not purge any of the lines .
the compressor still works when turned on but the Aux fan only switched on for maybe 1 minute and cuts out ...leave the motor sit for about 1 hour and compressor turns on and so does Aux fan but cuts out again
My theory is not enough gas in system and the HP must be low ....question ....on the Dryer would the HP switch control Aux fan so if pressure is low would cut out fan ...Wifie said the A/C worked when traveling at speed on expressway
I have gauges but R134a is on the way along with ultra violet kit and Vacuum pump just incase I have to strip the system .
waiting for your expertise on this
