1 - 5 of 5 Posts
I am planning on replacing the stock head unit (business cd) on my 2000 328ci. Will any aftermarket head unit (sony, alpine, pioneer, etc.) work with the H/K sound system? Do I need to buy any special parts?
Thanks for the help.
A bimmer chick moderator :)
yes any will work but if i were u I'd get an aftermarket stereo setup :pimpin:
how bout the controls on the steering wheel will they still work? do they have a kit that will still let u control with steering wheel?
The "12 speaker" HK system is still a 4 channel system, just with twelve drivers. To install the headunit, you will need a dash kit and a wiring harness.
To do speakers, most 6.5" Component speakers should fit up front. Some large ones will require you to dremel a plastic ring down just a little. I have Alpine Type-X components in mine, and those are one of the largest baskets out there.
As for steering wheel controls, you can use a Pac SWIX to keep those. Cheers!
1 - 5 of 5 Posts
