Ok guys, I have been battling my front endlinks. At first I used the stock endlinks when I installed my Ksport coils, but the ended up creating pre-load and snapped the mounting tab on the bottom housing of the coilover. So I did the "search" on here and found the impala endlinks and installed them yesterday but they are too short which causes the front sway to rotate up and gives me almost 4in of clearance to the control arm sitting on the ground. I ordered a set from ECS which were almost and inch shorter then those. All the adjustable endlinks I found like hotchkis are stock length and extend to be longer, not shorter.
Well low and behold a little searching on the internet and I found this website which seems to have many options. I needed an endlink that was around 9-10" in length and I purchased the 8'-11." I will keep you all posted!
http://www.hellwigproducts.com/products/off-road/adjustable-end-links/
Thought I would pass this along and give everyone an update when I get these in.
