1 - 8 of 8 Posts
· Registered
2002 320i
The ac randomly just shuts off and then starts again, i can hear the ac compressor turning on whenever i turn it on/off but the ac itself only sometimes works. It usually works for several seconds before stopping completely as in no air coming through. I've searched through a bunch of threads about this, but none of them confirmed it. I am suspecting an FSR issue, as it is one of the most common things to cause randomness in the AC. I just wanna know if anyone else has dealt with it and whether it solved.
· Registered
2002 330i, 2000 323i
If your AC is working but you are not getting air coming out of the vents regardless of fan speed intermittently that is a result of a failing FSR.
Once you get it replaced let us know the outcome.
· Registered
2002 320i
Discussion Starter · #6 ·
then just turn the fan to high with AC off, and see if air is blowing out the vents.
Tried that it is not blowing, however I noticed something odd, while driving at around 100 km/h there was heat coming through the vents which I assume is coming from the air going under the hood and the occasional fan kicking in.
· Registered
2002 320i
Discussion Starter · #8 ·
So just changed it, it was a huge hassle to get it replaced due to it being an awfully small spot and me being a rather big guy but got it done and it works perfectly fine. So it indeed was the fsr causing the issue.
1 - 8 of 8 Posts
