1 - 7 of 7 Posts
:banghead:Hi
i got a problem with my 2001 m3 100 000 miles. Each time i brake, when i am at +-20 miles/h , the system abs locks my brakes. Once i restart from the stop, the systeme abs comes off.
someones have an idea? I got no light in my dash!
The abs sensor are the wheel speed sensors, The modulator/ abs unit is the is the box with like 5 metal brake lines going into it. either located in the rear passenger side or on the rear driver side by master cylinder on models (03+)
Discussion Starter · #5 ·
Yeah oK! , i see it, my modulator never dit that before, i just swap my 4 brake ( sensor(use) big brake, and pad, and after , my system abs do this trouble. I got 4 abs sensor in my house , ill try to change it and see if there the problem goes out.
So my probleme can be only modular or abs sensor??
1 - 7 of 7 Posts
