1 - 7 of 7 Posts
I'm getting 3 ABS codes and i'm determine what they mean. I already know that i'm going to need a new ABS wheel speed sensor for the rear drivers side, but i'm trying to figure what the other 2 codes mean and where to find the parts
Motor vehicle Light Blue Automotive design Vehicle
Motor vehicle Light Blue Line Gadget
Motor vehicle Bus Gadget Audio equipment Plant
2000 E46 323i, 3.0L and 2.0L Z3's
In the E36/7 (Z3) world, code 71 (hex), pump, means that there are a couple of solder joints in the ABS unit that need to be repaired. Don't know if the early E46's have the same ABS unit or not. You'll have to do the leg work on that with RealOEM.
Attached is the data I put together when I a problem with my Z3.
Sorry I don't remember the exact fuse, but actually check the fuses for the DSC/ACS. One of the 30 amp fuses is for the pump motor. I had a vehicle with a blown fuse there which caused at least the pump motor code
Sent from my IN2025 using Tapatalk
1 - 7 of 7 Posts
