Hi, I want an E46 coupe, as a paraplegic w/wheelchair must use an automatic & my '86 528e is fading fast. Since many of you have more experience or knowledge with the E46 AT's is there one should I avoid? I can look at fluid color and feel shifts, but is there any way to tell if it might die soon via codes? What preventative measures are there, if any? We all know the motors are good for 300K+ miles and the BMW is a car that's fun to drive!
I looked at a 528i that uses A5S-390R and they guy had all maintenance records, but not the tranny & I asked the guy to check w/his dealer. He called Motorwerks BMW of MN and they said "Do not change fluid if things are working now or expect problems". I have been frustrated by mixed information about fluids as well. Not only from dealers, repair manuals, sellers, mechanics, but even BMW. If lifetime oil do they sell filters just for repairs not maintenance? Do you put the old fluid back in? On fixed income I can't keep buying vehicles then putting in another $1000, $2000 or more right away to keep them running. This is a great forum.
THANK YOU,
"The Token Gimp"
p.s. GM's 5L50E the replacement for the 5L40E is supposed to handle 30% more torque. My 99 240HP Pontiac GTP had 4L60E went out at 66K miles. After rebuild & rewired motor pushing 300HP tranny took a lot more of torque w/o issue :^)
ALL VEHICLE Automatic Transmission List FYI:
http://www.automaticchoice.com/Catalogue/v_index.pdf
THANK YOU,
"The Token Gimp"
