1 - 3 of 3 Posts
325i-FAULT CODES 0000FO, INTERNAL CONTROL UNIT FAULT A12 CONTROL MODULE NEED TO BE REPLACED CUSTOMER ADVISED.
The above was told to me after I took my 325i in to have the Air Bag Replaced per BMW North America recent Recall. The BMW Service Manager of the BMW Service center said repair the internal control unit fault a12 Control module it would cost me of $2600.00. Does any one know what is the control module function? Because all was well untill they replaced the Air Bag BMW north America Recalled. Is my life in danger?
You’ll want someone more experienced than myself to confirm this and the appropriate action to take, but a quick Google search for “E46 internal control unit fault A12” returns this translated page (see post #155-157): https://translate.googleusercontent...LkJrhhkInhv8R8GGkDHBp7V0OwFwJCscw#post3336877.
Searching for “E46 A12 control unit” returns ScottJoh’s webpage on K-Bus devices: http://www.bmwgm5.com/e46_k-bus.htm, which shows the A12 unit being the “Multiple Restraint System Control Unit.”
Lot of information out there on "E46 MRS unit" that you might search around for, but here are a couple quick reads that might be relevant.
Center Console Removal & SRS Module Replacement: http://forum.e46fanatics.com/showthread.php?t=734286
MRS control unit corrosion: http://e46fanatics.com/forum/showthread.php?t=929806
Whatever the case may be, it's likely a DIY and much less than $2,600 to fix. Hopefully someone more knowledgeable can chime in, but the above should get your search started.
1 - 3 of 3 Posts
