I've had great results with the magic eraser and wouldn't hesitate to use it occasionally. I think it works way better than conditioners. The eraser restores the non-glossy flat appearance of the factory leather in a way that conditioners don't. And it's not removing factory dye...I can look at the eraser when I'm done and it's dirty but it's not colored.
The proper cleaner, conditioner, and method will give you the same results without destroying the top layer of your seats.
what about old worn out leather? any ideas?
Leatherique rejuvinator oil + pristine clean, don't knock it till you try it. If you aren't in a warm climate, wait till summer to do it.
10 step method I use:
1.) Wait for a HOT day, hotter the better.
2.) Generously apply the rejuvinator oil on your seats. Use a crappy paint brush. Keep putting more and more on till the seats stop absorbing it. Don't cheap out, you'll need almost the whole (small) bottle for the entire car.
3.) Let it bake out in the sun for 24hrs. Again, hotter the better.
4.) Using a tampico skin brush (amazon, $6) brush the sh!t out of the seats and work the oil in there. Use some elbow grease and scrub it really well. The skin brush is designed for your skin which is less durable than leather so it won't damage the leather even if you scrub it hard. It will only loosen the crap that the rejuvinator got out. Rinse your brush out periodically otherwise you'll only be spreading the dirt. Warm water is fine.
5.) Spray the pristine clean on the seat and let it sit for ~2mins.
6.) Scrub the sh!t out of them again.
7.) Using a warm, damp cloth (microfiber or whatever, I use a terry one), wipe off all of the oil and cleaner. You'll need several towels after you see how gross your seats are. Be prepared for this.
8.) Use dry microfiber towel (not terry) to clean the water and whatever remains on the seat off.
9.) Touch your newly cleaned and conditioned seats.
10.) Be amazed and have a beer.
If your seats just look tired but not torn/cracked, this will do wonders. You can try out the water based method, I'm not saying that it's not better or whatever but this is what works for me. To maintain them after the oil, follow steps 5-10 every other month. Use the oil yearly or every other year depending on how bad your seats are/have gotten.
this has been mentioned before on here......People recommend that you recondition the seat with some kind of leather conditioner when using magic eraser since it is like sand paper. One time use is fine, I wouldnt use this all the time though.
Why take the chance? Do the right thing and get it done with properly. Would you take the same chance with a mechanical component of your car?
+1
oh wow. I am glad I have real leather seat. they just wear out but never crack.
They will if you don't take care of them.
