Hello everyone let me tell you what is going on with my 2003 325i it's driving me crazy. My a/c is blowing cool/warm air. The low side gauge reads 32 the high side gauge reads 178 and the temp. outside is 78. Just put in 1.6 pounds after vacuming out the old freon after putting in a new ambient air temp. sensor. Air was warm before I did al this but after these changes made it slight cooler. If I turn on the window vents (defroster) the air gets cold in the panel vents. Just run the panel vents go's back to cool. Also the center panel vents will blow warm air when the side panels remain cool. The only thing I can think of would be the heater control valve that's under the air box is stuck open. What do you think the problem could be? The pressure reads good on both low and high so it can't be compresser problems, or expansion valve problems. This is a new one on me. Please help!
