1 - 4 of 4 Posts
Hi, I have 98 e36
My motor is m43b18, the issue is when I shut the car down it acts like it's still going on and it moves up and down slightly then shuts off, sometimes that goes for around 1min and I kick down the gas pedal to make it stop doing that after removing the key completely. I did a lot of searching and I thing it***8217;s called engine stalling I***8217;m not sure
Can anyone point me in the right direction of what that issue is?? Just some idea of what to check
Discussion Starter #3
I don't get it. You jam the engine and the car keeps going?
When I kill the ignition “close the car and remove the key” the engine is moving up and down sometimes for almost a minute and I have to press the gas pedal rapidly to stop it doing that
Or I didn’t understood what you mean exactly
Also I found out recently that it might be a control issue “ECU” not the “ECU” it self but maybe the harness or a fuse that controls it
I checked the harness and it’s okay but I can’t find the fuse for the control??
1 - 4 of 4 Posts
