Status
Not open for further replies.
6-speed gearbox
1 reading
24K views 13 replies 7 participants last post by  VpointVick
#1 ·
My gearbox arrived today after a long wait. It’s supposed to be a gs637bz THEG 6 speed manual from a e46 330i. The only numbers it has are 1069401018 and 1069401016, and a getrag sticker with 0014326BEG. These numbers come up for a diesel.
Just want to know if I’ve bought the real deal, and not a much cheaper diesel gearbox.
#7 ·
It is a 6 speed. My main concern is that it could be a much cheaper diesel box. I would have thought ZF would have made the markings clear. The numbers relate to bz or dz.
#11 ·
Is there any physical difference between the diesel 6 speed and the petrol? I know it’s a gs637 (bz or dz). How do you tell it’s a Theg or Thea? I would have thought zf would have made it more obvious. Just wanted some confirmation before doing the manual swap.
#12 ·
There were several variations of this model gearbox, different ratios for z4/330/diesel/petrol with codes bz (Thea/Theg/TjegTjee/Tjes)
and gs637dz, which were for the diesel.
#13 ·
Measure how many turns come out of the output shaft for every turn of the input shaft, in each gear. Then look up the ratios- they are out there for each model. But don't get busy and forget to come back and tell us here whether you got the right animal, or not!
BTW: Did you get it from Europe/US? It looks a bit 'salty'.
Status
You have insufficient privileges to reply here.
