1 - 5 of 5 Posts
ok i got a phoenix gold 500.4 amp. they say to use 4ga. to power it. since the battery is so close to the amp do you think i could run 4ga. to my dis. block and 8ga. form the block to the amp, cause im playing on powering my basslink off the block too. what do you guys think?
0 gauge is certainly the most conservative way to go, but 4 gauge to the block/4 gauge to the amp should also work. It all depends on if you're ok with working with the 0 gauge given how large/thick it is...
1 - 5 of 5 Posts
