1 - 7 of 7 Posts
· Registered
i think the clear tail lights are the same as coupe, u can go oem from the dealer... they are expensive tho.. ~$300 ??
· Registered
convertible clears are not the same as the coupe. OEM only
· Dale Earnhardt's Double
Here's an install hint that wasn't in the DYI:
Use an 8" extension on your ratchet drive and a swival joint on the end with the socket to make the removal of the nuts a piece of cake. So many people complain about how hard it is to remove these and this little trick will save you time and frustration.
If you want to know the fastest way to do a job watch the laziest person (that would be me).
1 - 7 of 7 Posts
