1 - 3 of 3 Posts
Okay so on the way home from work just yesterday I was slowing down to a red light and my car shifted gears then started sputtering really bad, was still able to drive it to the nearest parking lot. Which currently is still drivable, just for some reason has a very bad sputter when you start it, give it gas, put it in gear, and on acceleration, doesn't feel like to much power has been loss though, im stumped and do not know what it could be, I have already went to see what codes are throwing and my mass air flow sensor, and o2 sensors are showing up, and i just changed my spark plugs a couple of hours ago, can anybody help??
Premium Member
Its not likely the MAF or O2 sensors that you are having problems with.
Post exact codes, Freeze Frame data and warm idle Fuel Trims.
If the fuel pump is original, I would consider this an item to replace soon.
Read my comments in this thread carefully. - https://contacts.google.com/u/0/preview/search/misfire
OG Fanatic
Broken DISA flap? I had similar behavior years ago. I would check the DISA.
1 - 3 of 3 Posts
