I have copied below from my thread in the FI section of the forum:
List of mods:
Stage 3 ported Technik head, 1mm Ferea oversize valves, double valve springs, titanium retainers, etc.
248/256 schrick cams
Raceware head stud kit
New hydraulic cam followers
M3 chain tensioner
New cam sprockets, chains, guides, etc. Chain are iwis race grade chains.
ATI super balancer
ESS TS2+ (Non ESS MS43 tune and setup)
S54 headers, modded with 2.5 collectors, Y piece into single 3 inch, two un-baffled mufflers. All 304 stainless steel
Besian vanos seals
Reservoir for liquid intercooler
Samco radiator hoses
Samco intake boot
BMW performance brake rotors
Zionsville competition radiator kit
Zionsville billet thermostat housing
80 degree Celsius mechanical thermostat
EMP Stewart water pump
Custom 65mm supercharger pulley
Turner sways front and rear
Turner urethane engine and trans mounts
Bilstein ride control coil overs
Custom in bumper cold air intake (K&N 6x9 inch filter)
UUC Twin Disc Clutch and Flywheel Package
SSG to 6 Speed Manual gearbox conversion
2.93 to 3.15 diff ratio change
OS Giken LSD
Subframe reinforcement
Solid Subframe bushes
Modified diff carrier (twin mount at rear of diff)
Bosch 42lb injectors
Aeromotive 340lph fuel pump
Remote pcv valve and catch can
BBS RSGT wheels
Now that I know I can and have tuned the car, it is time to build the bottom end, and some other mods I will reveal as they progress :shhh:
An order has been finalised, but with a 4-5 week delivery time for the following:
Arrow precision connecting rods
JE forged Pistons (8.5 compression ratio)
Main and rod bearings
MLS head gasket
The crank has been sent out for lightening, knife edging, and journal linish (journals on crank are immaculate now), and balanced.
The block is at my work, I am making a full main caps to block girdle, and side plates for the block. Once the girdle is fitted, the block will be bored and honed, and the main bearing journals line bored. Head and block deck will have a light cut to ensure flatness.
As long as delivery times quoted are accurate, should be swapping out the engine in 6 weeks time :excited:
I will then get the car running with close to the current setup to run in, but with a new aftermarket MAF, and then there should be some new toys to show and tell :evil:
List of mods:
M3 chain tensioner
ATI super balancer
Besian vanos seals
Samco intake boot
OS Giken LSD
BBS RSGT wheels
MLS head gasket
