Hi,
My 2002 330Ci is making a fairly consistent "gurgling" or "marbling" sound at idle, and more pronounced when idling and in D or R (RPM drops)
Somebody posted the same sound on youtube, so linking to it for reference:
http://www.youtube.com/watch?v=JHg3fxK1Hp8&feature=related
The sound is usually present, and happens when the engine is cold or hot. If If I put the car in D, with the brake pressed, and raise the idle to over 1100 RPM, the noise pretty much disappears. When the idle drops back down the noise comes back.
3 months ago I did a cooling system overhaul including new idler pulleys (both), new belts etc. I verified the cooling system is properly bleed, oil level is fine, premium gas etc. The noise started about 1 month ago.
This is a new one for me and hoping for some good leads.
TIA
RRG
TIA
RRG
