325i Manual transmission conversion
1 reading
53K views 29 replies 11 participants last post by  E46CiATL
#1 ·
Hey guys, im looking to swap my automatic transmission very soon, i just wanted to ask for some advice and tips from people who have done this swap before. Where is the best place to look for a good transmission and all of the components for the M/T, and how much am i looking at? Im not looking to buy a bunch of new parts, i am willing to pay for a quality transmission though, but im 18 so im limited with funds, but i have and $800 and counting of spending money. I appreciate any advice! Thanks
#6 ·
I did the manual swap on my '02 325Ci last year. I got the transmission swap kit on ebay from Quarry Motors in Florida. Paid $625 plus $80 shipping to CA. It included everything needed to convert the car to manual (trans, driveshaft, pedals, clutch, flywheel, footwell trim, dme wiring harness, shifter including the linkage, etc.). The transmission was from a 330 (ZF S5D 320Z), so I also had to replace the diff since the 330 propeller shaft has a different bolt pattern and will not mate to the 325 diff. I got a 330 3.38 diff from Quarry Motors as well, it was $150 and they shipped it together with the swap kit.
I then bought a new LuK clutch and flywheel off Amazon (they had the best price) and the rest of the parts I bought from Tisher (new shifter bushings, rear main seal, new master and slave cylinders, etc).
Good luck with your project. It was a bit costly but totally worth it. It's like driving a whole different car :)
#10 ·
To look up parts and part numbers.
I did the swap and do not advise it to someone on a tight budget. After you calculate all your costs add at least 30% and if you can afford that you should be fine.
You can do it cheap by finding someone parting out a car but you still need a lot of new parts that add up quickly. There are a lot of parts you can't reuse and others you shouldn't because you don't want to go back fixing thing every six months.
#12 · (Edited)
You will need manual transmission bushings. You also need to replace the bolts holding the transmission to the engine. The drive shaft bolts are also one time use. The bushings and other parts in the shift linkage should also be new. The clutch and flywheel can't be reused. (unless you have the special tools to reset the pressure plate it's cheaper to buy new)
Some parts should be new too, but don't NEED to be. The e46 is getting up there in years and you have no real way of knowing if a part is original or not. I recommend getting new master and slave cylinders, clutch lines, etc.
I also recommend getting new electrical parts. I used a clutch switch module I got used and it stopped working after a couple weeks. I spent hours jammed under the dash checking wires and rewiring thinking it was a bad connection. In the end I bought a new clutch switch module plugged it in and the car started.
There are a lot of parts and I can't think of all of them. Read through the DIY guides on here. You should pretty much buy all hardware, plastic/rubber parts, and parts that can leak new though.
Edit: I think the 325i has a 3.46. The only issue with diff/drive shaft is if you're mixing and matching between 330 and other non-m e46s. (I have a 330 though so maybe someone else knows more)
#14 · (Edited)
Don't take this the wrong way, but I am not sure you're ready to tackle this large of a project being so new to the E46. It is one of the most difficult projects there is on these cars. It is also quite expensive to do it right by replacing lots of small dealer-only parts. And after all the difficult work is done, there is coding the DME.
Give it some serious consideration and tons of thorough planning before diving in.
#19 ·
All of the parts are in the links I provided. Get everything new (except trans, driveshaft, clutch/brake pedal assembly). I had everything needed ordered from ECStuning pretty much. Get new transmission fluid (I used BMW MTF2), new exhaust gaskets (OEM), clutch switches, transmission mounts, shifter bushings, etc you name it. If you get a 6 speed take my word and make sure you get this part (it took a long time to obtain one and delayed the projector a week) part number 25117523847
#20 · (Edited)
I saw one auto-to-manual swap thread where he made a detailed list of parts. He listed each part by name, part number, source, etc., and it was complete. Have you searched around for threads like this? I'm sure you'll find the one I mentioned.
Edit: This is the thread I mentioned.
http://forum.e46fanatics.com/showthread.php?t=659314
You should definitely read those links posted by SolidJake. He has done the swap.
#23 ·
Make print outs from real oem, they will help you a ton. Make sure you have the right tools, and dry area, and atleast a week to work. When doing the pedals, take the whole bracket off, install the pedals on an workbench, then reinstall the bracket. The clutch line going from under the car was kinda difficult to fish up to the pedals but you'll get it, just pull back the carpet. And transmission removal would have probably been difficult, but i had a very skilled mechanic help me so we got it in and out in like 30-45 min
#28 ·
I have not coded my car yet, and we did have a lift, but if you can jack the car up high enough, it would probably be easier to use jacks, this way you can climb in and out of the car without having to lower it all the time. The drive shaft was a little difficult to get out of the diff, can't remember exactly how we did it, but we used a prying action, you'll get it eventually
