Yes, I have on a '99 328i which has the same brakes as a 2001+ 325i.lilherc79 said:Has anyone done this?
Fronts only.front and rear
What is necessary to do this?
The fronts are a direct swap. The rears are not thanks to a different diameter parking brake assembly. You may be able to swap the entire parking brake/bacing plate assembly but I have not tried it.is it a direct swap? or additional parts are required?
that's exactly what I would do, and was going to do, until I realized that my OEM 16" rims wouldn't have enough caliper clearance, should I revert to stock. :thumbup:simsima325 said:OEM Caliper and Carriers, while going with a rotor like Zimmerman OEM size, and a dustless pad
