421 - 440 of 519 Posts
· Registered
323iT - 323Cic
Discussion Starter · #421 ·
Finally done about 2,000 miles or so, since Manual Swap! I still have a few things to sort, however its been doing rather well! I am definitely getting more comfortable driving with three pedals. Makes it quite more enjoyable to drive for sure. Also getting used to this heavy DKM Stage 1 Clutch.
Speaking of which..
  • Power Steering Leak from Lines & Reservoir is getting worst.. (I do have replacement) Its just damn too cold and have zero motivation to fix it.. :ROFLMAO:
  • Exhaust Leak is getting worst from where my dad flipped the flanges and did poor welds (will be fixed soon and hopefully wont leak ever again)
  • Squeaky Clutch Pedal (Will investigate once its warmer out)
I also decided to ditch getting M3 Trailing Arms... I'll get a friend to merge 323i and E36 M3 parking brake shoe so I can run E36 M3 Rotors and retain E-Brake w/ Z32 rear calipers. When I was looking at the cost, it was a bit absurd. With that said, this might be the best route.
Lastly, I will probably wait till 2023 to do my subframe reinforcement, and might do a LSD too in the process? We shall see!
Speedometer Car Tachometer Gauge Odometer
Tire Wheel Vehicle Automotive lighting Hood
Automotive parking light Tire Wheel Car Automotive lighting
· Registered
323iT - 323Cic
Discussion Starter · #422 ·
Wagon almost got totaled Friday night from an absolute moron. Roads were a sheet of ice, and he decided to not stop. Thankfully I avoided him.
Next Weekend I am planning on getting my exhaust fixed, and dealing with leaking power steering fluid. Wagon should be all ready for Spring/Summer. Knowing my luck? Something is probably gonna break again lol!
Finally installed AVIN 4 w/ INDUKTIV Wireless Charger thing. Beyond happy with how this turned out. Definitely more OEM+ compared to my previous head unit.
Car Vehicle Gear shift Motor vehicle Car seat cover
· Registered
323iT - 323Cic
Discussion Starter · #423 ·
I replaced my original halogen license plate bulbs (passenger side one burned out) w/ LED ones. Link
I believe @///Mark_D is running something similar on his wagon or sedan? Stumbled upon a post from ages ago.
Automotive parking light Automotive tail & brake light Wheel Vehicle Vehicle registration plate
Replaced my Halogen Reverse Bulbs w/ LED bulbs. Definitely helps when reversing in pitch black. Link
Automotive tail & brake light Car Automotive parking light Vehicle Automotive lighting
Finally replaced power steering lines, and vanos line (again).. However the power steering pump decided it had enough, so waiting for a new pump to show up and replace it. Speaking of failed items, my valve cover gasket is already leaking. The gasket that came with the M56 VC was a Victor Reinz, which is pretty terrible. Bought an genuine oem VCG... So.. hopefully my issues with leaks are dealt with for a bit haha? :ROFLMAO:
Went to my friends house yesterday and we pulled the borla catback off. He cleaned up the welds, and we slapped it back on. Theoretically should have no more exhaust leaks for about a month? Haha.
Speaking of which, my friend has a pretty rad Single Turbo LS E30. It got tuned at Kassel and made about 600 to the wheels? However, that wasn't enough so he wants more out if it. I would be terrified sitting in the passenger seat.
Tire Wheel Land vehicle Vehicle Car
Car Vehicle Motor vehicle Automotive lighting Automotive tire
· Registered
'04 325i, '02 325iT
Hey yeah! I got a similar set on Amazon for my sedan a while back. Here was when I posted about them a few years ago.
I was fed up with the salt eating away at the wiring and bulb housings so swapping to the led's was supposed to be the long term solution. The LED's didn't last as long as I hoped though and died this winter again. Even after potting them in epoxy to try and prevent water from getting in they still failed. I haven't dug into exactly what went wrong, but I've got a replacement set to install. Here's how bright they were when new:
Car Automotive tail & brake light Vehicle Automotive lighting Light
· Registered
323iT - 323Cic
Discussion Starter · #427 ·
Catastrophic Failure... Part III, maybe IV at this point? :ROFLMAO: (Wagon is definitely bi-polar)
Clutch Pedal got soft, and wouldn't go into gear. I'm hoping its slave cylinder? Getting it towed to friends shop who did the swap and he'll deal with it. I ain't diagnosing this on my quick jack, since its there ill let him do my front wheel hubs both sides, and deal with my very crusty rear brake lines.
Automotive parking light Tire Wheel Car Land vehicle
· Registered
323iT - 323Cic
Discussion Starter · #428 · (Edited)
No update as of right now.
Got it towed over to my friends shop this morning. Hopefully he'll get to it tomorrow, or the following day. He does have a few customer cars that are on a tight deadline. Had to replace a N52 on a E90, and a blown transmission in a MK5 GTI.
I did add a few things since its there;
  • Replace both rear brake lines. (the brake line nut to the soft line is seized from rust, still running my factory soft line) so might as-well replace them and not have to worry about them for the future. -- Replacing the rear soft line with Stoptech Stainless Lines.
  • Replace both front hubs w/ bearings. I'll finally be able to use rotor screws since my current hubs have seen better days, and the threads are nonexistent. Its a nightmare taking my wheels on/off.
  • Figure out why clutch pedal decided to become soft, hopefully its slave/master cylinder and not the pressure plate.
Tire Automotive parking light Wheel Car Land vehicle
· Registered
'04 325i, '02 325iT
Hope you get it figured out and back on the road soon. I had a similar failure once (non E46) and it was the clutch slave seal that had failed. The fluid eventually leaked down enough that the master cyl reservoir went dry and started sucking air. Then the pedal turned to mush. I didn't notice any fluid leaking since the slave cylinder was on top of the transmission, and it all just sort of pooled there.
Since the slave cylinder is on the bottom of the E46 trans you might be able to poke your head under the car and see if it's wet.
· Registered
323iT - 323Cic
Discussion Starter · #430 · (Edited)
Unfortunately was much worst! However, I ain't "that" mad, considering I actually really hated this clutch. It was awful to daily drive with, considering how heavy the clutch pedal was! In traffic, it was miserable. Speaking of which, this exploded at 2600 miles, which is insane! I honestly believe this is a manufacture defect? It's a bit funny cause I was talking to some friends, and mentioned how I hope this clutch blows up so I can go OEM.... Guess my wish came true! :ROFLMAO:
Automotive tire Rim Road surface Art Sculpture
· Registered
323iT - 323Cic
Discussion Starter · #431 · (Edited)
Ended up going with this clutch -> BMW Flywheel Conversion Kit. It is definitely an adjustment going from a very stiff clutch pedal, to a softer pedal (more OEM like) and a tad higher biting point. However, It's much more tolerable to daily drive! With that said, the starter is sticking a little bit. I'll have to order a new starter and replace it before it fails :rolleyes:.
I did confirm as-well there is no more leak from the front end.... Well minus the VCG seeping from one of the half moons. I have a new VCG, and I'll do it properly. (its seeping because of my lack of experience when I did it last year).
Car Automotive parking light Wheel Tire Land vehicle
Ended up snagging a toolbox cart from Harbor Freight, got a bit annoyed being disorganized, so this will definitely help with future projects!
Gas Wood Machine Asphalt Metal
· Registered
01 325i Touring. 07 E91 Touring. 90 Chevy C2500 RCLB.
That’s the same kit I’ve got for my manual conversion. Unfortunately I haven’t been able to put in any time behind the wheel to give you a review. Nice box!
· Registered
323iT - 323Cic
Discussion Starter · #433 ·
I've only driven like 50-60 miles with it ish? Its a easy clutch, and rather enjoyable! Still in the break-in process, however I enjoy it way more then the DKM Clutch I had.
· Registered
323iT - 323Cic
Discussion Starter · #435 ·
We put one in my wife's R53 Mini Cooper S about 2 years ago and love it. I have one to go in my touring with the ZHP drivetrain when I get to it.
Sent from my SM-G970U using Tapatalk
My dad had a R50 few years ago, that he converted to a 6 speed! Such a great car to drive, such a bummer he sold it.
· Registered
323iT - 323Cic
Discussion Starter · #436 ·
Welcome Stella to the fleet!
Its a 2000 323ci w/ around 133k miles paired with a 5 speed (Fern Green Metallic w/ Tan Interior). The second owner bought it in 2003, with 23k miles and it has been dealer maintained since! Two options that stand out is (Harmon Kardon and Auto Dim Mirror w/ Garage Door Opener). It drives insanely well, and the M52TU sounds super healthy and not a spec of rust on the body either! It's going to be a fun new daily, and especially during the middle of summer!
Wheel Tire Car Land vehicle Vehicle
Wheel Car Tire Land vehicle Vehicle
· Registered
Speaking of which... I saw @Gottalovethexi Sedan with Eisenmann Muffler with Meisterschaft DTM tips. Sure it might stick out a bit, but Iove it. I could staggered a little too like the Borla Tips are. My wagon is aggressive as it is, and I feel like this would be a great touch. Probably won't be liked by many but thats okay!
First time logging on in YEARS and I see I have notifications 😂 can't believe it thanks for the tag!
I JUST sold this car a couple months ago and it was a sad day 😔
· Registered
323iT - 323Cic
Discussion Starter · #438 ·
What a bummer! Hopefully you enjoyed it during your ownership.
· Registered
323iT - 323Cic
Discussion Starter · #440 ·
Nothing really new, finally broke in the new clutch.
Still procrastinating on;
  • Valve Cover Gasket
  • Starter
  • Front Wheel Hubs / Bearings
  • Stud Conversion
  • Fuel Pump
Then dealing with the rear subframe. :ROFLMAO: However.. My funds have been stolen with my 323Cic which needed some love. Speaking of which I could've done my subframe and have a LSD with the amount I invested into the Vert already. Oops. So it will have to wait till like next year!
I do want to redo my CCV Breather Hose from the M56 Valve Cover, fix my cross threaded O2 Sensor on Bank 1, and do a whole checkup. Have to figure out why the Wagon get barely 17-18mpg, and the Vert is getting 23mpg. Def got some blues clues to do! (Probably my stupid aggressive tune, which I might flash my previous tune, and compare fill ups)
I did end up replacing my inner tail lights back to OEM, snagged a brand new set of inners for like 110$. Definitely like the look of these inners compared to the aftermarket ones.
Wheel Car Tire Vehicle Vehicle registration plate
Wheel Tire Car Vehicle Hood
Car Land vehicle Automotive tail & brake light Vehicle Automotive lighting
