Hi,
I own a "02" 318i Executive. I am looking at purchasing and fitting an M3 front bumper that I have found on the web.
As some of you may know, this particular model doesn't have fog lights, instead it has painted plastic bulb looking components which fill the holes where the fog lights would usually go. (if unsure see the image below, hopefully it shows up).
The M3 bumper that I have found comes with a set of fog lights which is great. Now the fog light button next to the steering wheel lights up when pressed so I assume it is somewhat active, but does anyone know if I will have any trouble hooking up the fog lights with the existing system, and will it work easily enough or will i have to either invest in some cable and components myself, or is it best to take it to a mechanic/auto electrician ? I can follow instructions if provided but am not electronically minded as such.
Also any suggestions or tips on fitting the bumper itself would be appreciated, there are a few great tut's on here but any extra info would be welcomed.
I apologise for any rookie errors in posting, this is my first post.
Thanks in advance !
Thanks in advance !
