1. What gauge is the sheet metal where the subframe bolts to chassis?
2. I have subframe out and trying to detach axles from the differential. The six bolts on each are out and the outside ends of the control arms are detached from the trailing arms, but the axles don't come off. Should I pry where indicated in picture below?
3. I've been reading about input flange swaps. Pinion preload is critical. When removing and putting back on the same flange, you mark the nut to the flange and reinstall to the mark. But what if the input flange is different? Does the following sound like a reasonable approach? On new differential with incorrect flange, mark nut to flange. Loosen nut. Tighten nut with torque wrench set at estimated needed torque. Tighten nut to mark. If wrench clicks at same instant, stop. If it does not click at mark, repeat loosening, setting torque, tightening nut until wrench clicks exactly when nut aligns to mark. Remove nut and install new flange to final torque setting.
