1 - 8 of 8 Posts
will 3.91 differential work on an M3 with an SMG II tranny? some people say yes and some say no. so i dont know.
just want to see what you guys have to say?
Senior Eurowerkz Member
you should call dinan
they would tell you. and by the way they have 440 gears for the m3. i was going to call this week but got bussy at work and forgot to call. let me know what they say please.
bobm3 :thumbup: :thumbup:
My 3.91 diff works perfectly with my SMG M3. It is by far the best mod. I have had it on for ~5 months now.
BoGiE
P.S. What are your redlines with the Eurobahn software?
Are yours all different also?
1st-8000
2nd-8050
3rd-8200
4th-8250
I like Techron
Re: you should call dinan
4.10 or 4.40 gears are off the top for E46 M3 application. Stick with the 3.91 upgrade as it is far for driveable...
thanks alot for the information
can you let me know how much was it to change the rear gear for the m3. from the 364 to the 391 gear. i would think it would be cheaper sence you got the set up already. and it would not be
like over the 2,000.00 range ? i forgot the exact amount that i saw in another post.
can you let me know how much was the 391 gear to put it in your m3. thank you in advanced about this really.
bobm3
Evosport did mine. I believe I was charged 2800 installed (the going rate at the time with no subsitutes). Install runs around $350-400.
BoGiE
Discussion Starter · #8 ·
BoGiE
1st-8000
2nd-8050
3rd-8200
4th-8250
my redline is still 8000. do you ahve the eurobahn software too? and are those your redlines for each gear? and how is that possible?
1 - 8 of 8 Posts
