1 - 11 of 11 Posts
I would like to know if anyone ever had 245/40/17 up front with their m68 or if anyone know whether they will fit or not without rubbing. Thanks.
Try it out!
Swap the fronts and rears and see if they fit :thumbup:
(\OO\ (||)(||) /OO/)
They will fit if you use a 10mm spacer. The offset for 17x8.5 rims in front needs to be somewhere lower than about 42 or 43, IIRC.
Discussion Starter · #6 ·
coolio4433 said:
Try it out!
its easier to have someone tell me than to go swap it out just to see if it works. I dont have all the tools around my house so that makes it a bit difficult too.
Yes they will fit
Autocrossers routinely run 255/40x17 Kumho Victoracers and
245/40x17 Hoosiers (which run almost as big as the Victos)
on stock M68 staggered set-up with no problems at all.
Mike M
Discussion Starter · #8 ·
the weird thing was that when i purchased these wheels off of soemone they were all 17x 8.5 all around. but i guess that should fit still right?
No more E46 :(
Mike M
Thanks! That's good to know. :)
See post #4 above.
See post #4 above.
i had a flat and a full size spare m68 for the rear...i put it on the front and yes it indeed rub slightly a 5-10mm spacer would have worked out well...it was just to get the front wheel patched
I'm running 245/40-17 all around on 8.5" wheels and have no problem. I'm running stock sport suspension though.
edit: I measured a 4mm gap between the inside sidewall and the strut. The tire will rub the strut at full steering lock, but I don't think that's an issue considering how little time we drive at that steering angle.
1 - 11 of 11 Posts
