I've been busy reworking the sound system in my 2005 BMW 330ci and thought I'd share some of the design decisions and work I've done, not that there is anything spectacular here, but maybe someone will benefit from some of my approach.
History
I ordered this car new with factory navigation and the Harmon Kardon sound system which was standard equipment on the coupes. It was decent and I lived with it for about a year before I got around to installing equipment I've had in two previous cars.
Originally I installed a/d/s/ 335is 2-way component speakers in the front doors with the tweeters in the stock midrange location (next to the door handle) and mid-bass in the stock location mounted to the door card. I had a 10" DVC sub in a sealed box in the trunk and all was powered by an a/d/s/ P840 amp. The equipment board was under the floor in the spare tire well, unvented and no cooling fans.
This system suffered from a few problems. The first was a lack of midbass in the doors. I never could get a good blend with the sub and it just sounded poor. The second problem was a lack of subbass mainly due to lack of power to the 10" sub. I had four channels of the P840 bridged to send 120w to each coil separately for a total of 240 watts... it wasn't enough. The third problem was lack of ventilation for the air coold amp. The first legthy road trip I took with the car resulted in a total amp melt-down one hour from my destiation which was 6-7 hours away from home. The return drive was tune-less, but the sweet music of the 3.0l I6 was entertaining... if not a little lacking in variety as I traversed the unteresting California I5.
Enter version 2.0
Since I fried my amp and had a few other issues to deal with I revamped the system. I used the same front components, but this time I cut a hole in the door shell behind the speaker location, fashioned baffles out of MDF and sealed the baffle to the door with non hardening modeling clay. I purchased an Image Dynamice IDQ12 D4v.2 sub, built a new box for it, and replaced the P840 amp with a DLS Ultimate A5. The midbass improved greatly as did the sub bass. This was fairly decent for a couple of years, but something changed and the front stage became harsh, shrill, and lacked midbass and midrange which made me not even want to listen to it anymore. I deduced that something had gone wrong with the tweeters after 10 years of use in three different cars. The midbass disappearance was another puzzle.
Enter Version 2.5
I decided I had to do something with my system or I was just going to rip it all out and go back to the H/K stuff. I started looking into component sets and was pretty set on DLS until I found a post by Scott Buwalda offering a sizeable discount on some demo sets of Hybrid Audio Technologies Claris and since another member at E46Fanatics had installed a set of these in his M3 (dumptyhumpty here too) I knew they would fit. I corresponded with Scott and had a demo set on the way to me at a considerable savings over the DLS system I was looking for including a full year of warranty and trade-up value assurance.
Since I was going with a 6.5" mid-bass vs a 5.25, new baffles were needed. I used solid oak and MDF to make these new baffles. The MDF was used for a 1/2" thick ring largely because I had it around and didn't have access to 1/2" oak so I improvised.
I cut the rings with a Japser jig, but it wasn't an easy thing to do (at first) mainly because when I purchased the jig I asked the guy at Woodcraft to get me a router bit that would work well on the solid oak. He recommended a spiral bit and I was off to work on the rings. I fussed with the setup to get the perfect size ring testing out on some 3/4" MDF and I wasn't getting a very smooth cut from that bit. It took me several tries before I gave up on it and went with a straight fluted bit I had from some previous projects, this worked much better.
Here you see the spiral bit result vs the fluted bit result. Both are solid oak and the front ring shows the rough cut of the spiral bit. It chewed up the oak pretty badly no matter how many passes I did, but the straight bit produced a smooth cut with just two passes.
Once I figured it out I made four rings: two were 3/4" solid oak, two were 1/2" MDF. I also cut a 1/4" thick ring out of masonite to be used to simulate the thickness of the speaker rim to help determine the thickness required to mount the driver with the proper depth. I ended up with a 2" thick baffle/ring setup and just enough space between the grille and the driver, perfect!
Making the baffle
Since I had done this before and all the hassle of aligning the baffle with the door and card was already done, I used the old baffle as a template for the new ones. The main benefit was size and position of the mounting holes which saved a lot of time.
My approach for aligning the rings worked really well. First I had to shave all the plastic from inside the door card to allow the 6.5" driver to fit properly. This required me to cut one of the mounting posts for the factory speaker completely off, then using my dremel I shaved down as much of the remaining plastic as I could.
I mounted the baffle to the door...
Assembled the rings together with blue painters tape and stuffed them into the door card with double sided tape on the baffle side...
I reinstalled the door card with the rings in place and they stuck to the baffle for perfect alignment...
I then used the rings to draw cut/alignment lines on the baffle, cut out the hole, glued everything up and the speaker mount was ready to go. I also made an additional support which I glued in place.
History
Enter version 2.0
Enter Version 2.5
Making the baffle
