1 - 20 of 91 Posts
I have an '04 Silver gray over alcantara ZHP that was hit on the driver's side.
Quick run down:
- 141k miles (was being daily driven before accident)
- four door
- manual
- alcantara interior
- xenons
Driver's side rear body panels and doors are junk. Front fender still good.
Hood, trunk and passenger side are undamaged, just normal wear.
Has anthracite headliner, A, B, C pillars, etc. so good candidate for a swap to black headliner.
Complete M54 motor with ZHP cams, higher redline, etc. Ran well and was daily driven before accident.
Have complete wiring, ECU, EWS, etc. needed for any type of swap.
Seats are a little rough but all there. Small hole on driver's side bolster. Passenger side is pretty clean overall. Rear seat had some kind of spill a while back that stained the back rest and bottom. Could be used for parts or to harvest cloth to fix up other seats.
Style 135, 18" wheels have newer tires but are rims beat up.
Parts that are already spoken for:
- six speed trans, clutch and flywheel, driveshaft, shifter
- door panels
- cube trim
- carpets
- dash
- center console and armrest
- front and rear door speakers
- exhaust
- brake ducts and center vent
- axles
- engine
- DME, EWS, etc.
- wheels and tires
- steering rack
- headliner and pillars
- shift knob
- kidney grills
- passenger rear door seal
- passenger fender (pending)
- rear view mirror
- front rotors
Body has been sold but still have lots of parts.
Available:
- xenon headlights: ZKW, one of which is almost brand new
- front calipers
- rear calipers and rotors
- front and rear sway bars
- fog lights
- front turn signals
- tail lights
- black sun visors and grab handles
- secondary air pump
- airbox
- front bumper (pick up only)
- rear bumper (pick up only)
- front and rear seats (pick up only)
Located in Richmond, VA. Let me know what you need!
Front wheel wells, right and left as well as the covers that are right in front of the wheel wells (here's a part # for one side) and brake ducts with mounting brackets.
Also, what condition is your front bumper?
Shipped to 60031?
Sent from my Nexus 6 using Tapatalk
Discussion Starter #5
Shipped to 60031?
Didn't see a P/N come through but guessing you're looking for #8 and 11?
Front bumper is ok. There's scratches underneath from bottoming out and there's a crack on the passenger side near the little lip extension. I'll grab some photos tonight.
Yes, 8 & 11 are correct. If in good condition then let me know what you want for those. Thanks
Assuming the car had AC, I am looking to buy the center AC vents no broken louvers or mounting clips please. Ship to NJ 08840 if it didn't go with dash. Thank you
Discussion Starter #9
It should be good, I'll double check tonight though. $25 shipped to 08840
Front turn signal assemblies to NY?
1 - 20 of 91 Posts
