So I was able to complete an auto to manual swap in my 2002 330Ci. I was able to reprogram all the modules to get rid of the gear icon, however my gauge cluster tacho must have broke as it doesn't work. I was able to pull another cluster from a 2005 330 and of course the tamper dot appears. Also the traction control light is on.
From all the reading, since the new cluster is newer it most likely can't be reprogrammed via PA Soft. I tried NCS Expert and it doesn't work (FGNR SHREIBEN). It sounds like the only thing I can do to get rid of the tamper dot is to reprogram the LCM to the new clusters VIN. Once those 2 modules agree, the tamper dot will disappear?
Also, I'm not sure why the traction control light is on if anyone has any suggestions.
