2002 E46 325Ci Convertible Electronic Issues PLEASE HELP
708 Views 4 Replies 4 Participants Last post by  MiguelAvila
Hi - new to this community! Urgently seeking help.
I bought my E46 a year ago with no issues.
My thermostat went out and I went to get it replaced at a shop. After I got it fixed at the shop - all these issues started appearing.
Remote locking issues
Over the course of a few months, I noticed that occasionally the doors wouldn't lock via remote - only manually. Even after locking manually, the indicator light by the gear selector stays on even though all doors are closed. That's not really a big issue as I am still able to lock manually it's not too big of a deal.
Turn Signal Issues
Then more recently, occasionally when I used the car, the turn signal indicators would not indicate on my dash. No sound or visible light. Same thing with my fog light indicators - although I can hear the fuse when I'd toggle the fog lights on or off. Everything on the outside of the car would work, just no indication of what's going inside the car.
Convertible Top Issues
Recently, my expansion tank cracked and blew after a long drive. Totally expected and due for a change. I left the car in my driveway for a week or two (busy with work) and when I went to start the car to work on it, the convertible top would not go down. I ended up swapping a new expansion tank and upper radiator hose and fixed my cooling system issues. However, the convertible top still will not go down. It has a red indicator that lights up but doesn't flash. Nothing happens, no noises or anything.
I had a theory that since I installed an aftermarket radio, maybe it was drawing too much power and started the electronic issues. I uninstalled the radio and unplugged everything - nothing changed.
Car Shakes Now lol
Also note, it has not been 2-3 weeks since I touched my car and now it shakes when I start it, still all the same electronic issues. What should I do?
Any help will be much appreciated. Thank you
Albert
See less See more
1 - 5 of 5 Posts
Not sure if you know about this, but the Expandable Compartment in the trunk (it's for the Convertible Top when it is being lowered) needs to down so that the Convertible Mechanism can begin working.
Once you go to the trunk, you will see the Illustration Sticker on the Expandable Compartment that provides instructions.
yep forgot to mention that the compartment is lowered. matter fact I don't think the sensor is broken, When it is lowered, I get a red light with no flashing and nothing happens. If I put the compartment up, I get the lower yellow light that indicates it needs to be lowered. Really not sure what to do
I'm no expert, but 2 thoughts come to mind right away. Check your battery. A less than stellar battery can cause all kinds of seemingly unrelated gremlins to appear in these cars. Things you would not guess are battery related.
Also, have you used INPA or BMW 1.4 Scanner to read any codes the car might be throwing? These are great tools for diagnostics. The cables are cheap on Amazon/eBay and the software & installation instructions can be had here: BaliDawg's easy install
  • Like
Reactions: 1
If something is pushing up the expandable compartment, it will trip the sensor and not allow you to open the convertible. Happened to me when my car cover slid forward and push up slightly the compartment.
1 - 5 of 5 Posts
