1 - 15 of 15 Posts
· Registered
I have a 2002, 330i with 114K miles. Am I ready for new oxygen sensors?
An engine warning light comes and goes(it started around 100K miles). Performance is still OK. With new O2 sensors, would my MPG improve?
Any advice?
· Registered
There are four O2 sensors. Two Pre-cat and two post-cat. The Pre-cat will affect MPG (via fuel and air ratio). Post-cat only for emmisons passing. Ensures that the post cat emissions are good. No affect on performance, unlikethe Pre-cats.
BMW OE O2 sensors are $200 each. BOSCH OEM are $65 each. DIY requires a speical O2 socket. you can do both in under an hour. They are standard and can be purcahsed at any auto store. There are two socket types. One is a crowfoot and the other a standard socket with a slit onthe side to accomodate the connected wire. It basically allows the socket to slip over the O2 sensor and let the wires hang out.
I replaced mine around 55K and I saw a noticeable improvement.
Also, do a search, as there are many lengthy threads on O2 sensors.
· Registered
Check autohauzaz.com. I just got two O2 sensors, oem, for $125 shipped.
I don't know what you are talking about. Just checked them and it was $132.00 for one O2 sensor and $109 for the other. How did you get both for $125 shipped?
· Registered
· Registered
BTW, you can rent an O2 Socket tool @ Autozone for free (free is nice when it comes to BMWs!). You give them $25 and when you bring it back, you get your $25 back! Get the tool, it will help you infinitely when doing this.
· Registered
True!
AZ also loans out other tools and even torque wrenches.
· Registered
Any advice?
What code? If it's a code for the post-cat sensors, there may be not be anything wrong with them. I believe there's a TSB out for 330s regarding this... search the forums.
1 - 15 of 15 Posts
