1 - 4 of 4 Posts
Greetings
I'm wondering if someone can provide me with a second opinion of what this dashboard error msg means?
it's a yellow circle with 3 dotted lines each on the right and left hand side?
I suspect it means the brake pads are beginning to wear out? but, i don't feel any difference in the braking power or any noises when I do brake.
Any suggestions?
Thank you-
Banned
Brake pads I think
sent from my dahc-6900 using Bimmer App
definitely brake pad wear light. but make sure you order a new brake pad wear sensor too because since the sensor tripped, it wont turn off. very cheap part and easy install though :thumbup:
Yep! Be sure to check your rotor thickness too as you may need new ones. Minimum thickness is on the rotor just fyi.
1 - 4 of 4 Posts
