1 - 2 of 2 Posts
BMW 2001 330i Sedan
Black on Black with Leather Interior.
Miles 128.335
Trans Type ZF Automatic
Series 3’ E46
Engine M54
At January / February 2018 Miles 123.655 the Following Work was Done to Restore and Maintain Machine at Top-Level:
Replace Valve Cover, and Gasket and Oil Separator CCV Refresh Kit to correct oil leak.
Replace Bad Oil Level Sensor, Change Oil and Oil Filter, Air Filter, Cabin Filter.
Change Differential Gear Oil, Replace Spark Plugs, Replace All Ignition Coils, Change Fuel Filter.
Replace Head Light Bulbs With H7 Sylvania Silver Star Ultra.
Replace Washer Fluid Tank and Pump,Replace Windshield Wipers.
Installed New Battery.
Replace Front Lower Control Arms, Front Sway Bar Links, Front passenger side tie rod end.
Installed OEM Bilstein Front Struts, New Springs, and Towers, Tower Boots, Bump Stop etc.
Installed OEM Bilstein Rear Shocks, New Springs, Boots, Bump Stops etc.
Installed New Frond Calipers and Brake Hoses, Frond Brake Rotors, ZIMMERMAN and Acebono Brake Pads.
Installed Rear Brake Rotors ZIMMERMAN and Acebono Brake Pads, Flush Brake System With Fresh Brake Fluid.
Paint Front and Rear Calipers and Brackets RED with POR15.
Installed New 17X7.5 SPARCO TROFEO 5 Light Gray Rims With 225-45-17 MICHELIN PREMIER A/S Tires.
Did 4 Wheel Aliment.
Car Will Have Original Rims Also.
Installed Whether Tech Rain Guards.
Installed BMW all Whether Mats.
Replace Fuel Pump and Intake Manifold Actuator.
BMW Dealer Replace Front Driver and Passenger Air Bags Under Recall.
1-12-19
Miles 127.675
Change oil and oil filter
Parts Used for All Work, only GERMAN OEM Nothing But the Best.
This is a Well Taken Care Machine, It Is NOT to Be Evaluated by Used Car Book Value.
Only Auto Enthusiast Will Understand and Appreciate All the Work That Was Done.
Please only serious inquiries.
Asking $5,250 or Best Offer.
Thank You !
1 - 2 of 2 Posts
