its 220 something at the flywheel.MIKEinTHE323i said:i thought it was 220 something
:yikes:Amir said:Lower #s are a stock 330 manual...
Matthew78 said:that's the type-s with the automatic that makes around 200 whp.. i don't know what the manual versions make, but it's more than 200 for sure...
It's a new GT35 turbo, with a 3" inlet running 55lb/hr injectors and a 12" front mount intercooler core with ceramic coated pipes. I'm running an HKS Super Sequential BOV and it's running fine venting into atmosphere (knock on wood).l330if83 said:thanks amir, wow, I don't even think the 3.2 CL Type S with 260hp make more than 200whp. Those are some sweet numbers, what kind of turbo do you have? And doyou hae a BOV? Personally, that would be the first thing I'd get after my turno (if I did get a turbo)
Just the looks from people as I pull up in a bimmer and blow off is worth the price of the entire system, and people point at my FMIC and give me a thumbs up :thumbup:![]()
xS3x said:
since when you got a turbo?![]()
heh heh I was thinking the same.BMWDon said:Something stinks in here!!!.....how much BS are you putting down Amir!?!?!? :lmao:
You're not serious are you? I think you would of said something damnya!
:yikes: :yikes:Amir said:
A little treatment courtesy of the man at Technik![]()
