1 - 4 of 4 Posts
The front latches work fine & the top opens about half way & then stops, the boot opens and is ready for the top to fold into its storage area. 3 years ago I put in a new wiring harness & I should add the I use my top down more than up, which is where it is now….HELP.
I had same issue and my battery cables were loose. My fault I had replaced it and forgot to tighten connectors properly.
2002 330 Ci
Could be the pump itself. Mine get's stuck when it opens and closes and I have to help it along.
Currently have my pump all apart. It was full of crud even after I changed the hydraulic fluid.
Harness to the front?
1 - 4 of 4 Posts
