Hello,
First time poster here. I've got a 2000 323i that is now in "limp" mode, with the EML and DSC lights on. Any help would be greatly appreciated, as I've poured through countless forums and still do not have an answer.
History:
The car originally presented with the SES light on and a code(s) (can't remember which) that pointed to a vacuum leak. So I decided to replace the entire CCV system and all vacuum lines. I did it the "right" way and removed the intake. However, when putting it back together I forgot which vacuum lines went where. I think I got all the vacuum lines correct, but don't know for sure as I couldn't find a diagram anywhere online.
Once I got the car all back together, I tried to start it. The engine would turn over, but refused to start. After digging around on forums, I discovered I switched two of the wiring harness plugs. This caused a 30amp fuse to blow. After replacing the fuse, the car started up.
At this point the engine refused to go over 3000rpm and by all indications was in "limp" mode with the EML and DSC lights on. Using INPA, I cleared all codes and reset the adaptations. When I started the car, all the lights went off. However, as soon as I pushed the pedal a little, the lights came back and the car was back in limp mode.
Following several posts, I used a multimeter to test continuity on the wires going from DME to the MDK; test PASSED. According to the manual, this indicates a bad MDK. So, I ordered a USED one off ebay. After putting on the "new" MDK, the problem persisted.
I once again turned to the forums. One suggested that even with proper continuity in the wiring harness, it is possible the connector has cracked/broken. So I, stupidly, decided to order a brand new wiring harness (as mine had tears in the sheathing and broken connectors in other locations). After installing the new harness, I still have the same issues...
Current Status:
EML and DSC lights illuminated on the dash
INPA reads:
169 MDK output stage control after diagnostic failure
Error frequency: 2
Logistic counter: 40
Engine speed 864.00 1/min
temperature intake air 25.50 Grad C
Battery Voltage 13.67 V
temperature cooling water 59.25 Grad C
appear before (rel.) 0.00 h
114 avtivate motor throttle valve
Error frequency: 1
actual valve throttle poti 5.62 Grad DK
nominal data Throttle valve 0.00 Grad DK
temperature intake air 30.75 Grad C
Battery Voltage 13.77 V
I am at a loss. I love this car, but can't justify putting much more into it. She's 20 years old with 210k miles. If anyone has any suggestions, please let me know.
Thank you for your time.
History:
Current Status:
INPA reads:
Error frequency: 2
Error frequency: 1
