I've been told that my 2000 323ci 5 speed has a 3.07/1 final drive. Is it possible to throw a 2001 325i diff in with little work? Will I have to swap flages? Is the 325i a 3.15/1 or a 3.46/1? The diff in question is from an auto if that matters
Try going to http://www.my330i.com/gears.php . It's a gear spead/shift calculator. I don't know how accurate it is, but it should provide some useful estimates.:dunno:jco said:Ok so here's the real question, what kinda of rpm's am i going to be running at 80mph with 235/35/19s with 3.46:1. I've got stock 225/55/16s now and @ 80 mph i'm turning close to 3400rpm with 3.07:1s,
4000rpm with 3.:46?
Anyone know the equation my 5th gear is 1:1
I'm not frank but changing the differential gear ratio changes your car's overall gear ratios. Which basically changes how fast the engine has to spin to make the wheels turn at any given speed. A funny thing is that a higher numerical ratio, like 3.46 vs. 3.07 is called a lower gear ratio when you are talking about it.UNCG323ci said:frank,
how does the whole thing work, im curious to this mod and it seems like a good idea. and btw the 323 is not so slow to me. my previous car was an automatic civic.... so i still find it hella fast![]()
