1 - 6 of 6 Posts
http://www.bimmernav.com/store/catalog/product_info.php?products_id=91
Setting
Before the clock can be set, the
time must be showing in the
instrument cluster display.<
With the ignition key in position 1 or
higher.
To set ahead: turn the right button to
the right.
To set back: turn the right button to the
left.
The adjustment speed will increase the
longer you continue to hold the right
button.
To change the display mode: press the
right button briefly.
Every time you press the button, the
clock display alternates between the
12-hour and 24-hour mode.
Discussion Starter #3
k i goet the clock part i think
for the bluetooth is there a OEM version available so i don't have to loose my cupholders
i think i heard someone say that it was already pre wired and it being behind the dash i searched for the thread can't find it.
Yes, there is an OEM bluetooth setup for 2003 and later, I believe. Check with your dealer or one of sponsors on here. Double check that it works with your phone, as it doesn't work with all devices.
There is a Parrot CK3000 Bluetooth system that plug ***8216;n***8217; plays using your BMW***8217;s factory phone hook-up and steering wheel controls for about $450. It has a microphone, stereo auto mute and under-dash stealth install.
Cheaper without the steering wheel functionality.
1 - 6 of 6 Posts
