1 - 6 of 6 Posts
Will 19x10's fit on a '04 coupe in the rear??? if so...what offset do I need???...will I have to roll my fenders??.....what suspension setup should I get....H&R cup kit be ok????:dunno:
Senior Eurowerkz Member
on your car it won't fit
i think only a m3 can fit 10"wide rims in the back of the car. i
think you would have to roll your fenders back to make them fit.
and if you do that make sure you go to a place that does good work on that. because it is very easy to chip or crack your paint job. when they are in the process of rolling your fenders.
bobm3 ;) ;)
I have 19X10s in the rear of my 2000 coupe. You will need a high offset right around +43, +44, mine are +44. My car isn't lowered as of yet, I have the sport suspension and with two people in the car I don't rub. I have yet to roll the fenders but you will have to if you plan on dropping the car.
Tires are also important you want one with a round side wall, Toyo T-1 s are highly recommended.:thumbup:
Sorry, I should have been more specific; 265/30/19 is the size you will have to use. 275 will rub like crazy, M3s have a wider flare in the rear than the standard E46 that’s why they can use a 275.
1 - 6 of 6 Posts
