The bottom of the passenger door fills up with water when it rains but I cont see where the water is comming in from even when I go through a car wash. Any ideas?
Door drains and vb. Search me and drains for location...on phone...tough typing on it!The bottom of the passenger door fills up with water when it rains but I cont see where the water is comming in from even when I go through a car wash. Any ideas?
I know...waiting for band o fanatics to take my pc...for general well being...pun intended!^ good thing you're on your phone. Keeps you at bay with the long and rather crazy posts.![]()
Doug, enable Swype on your phone, and you'll be back to your "full swing" posts in no time.^ good thing you're on your phone. Keeps you at bay with the long and rather crazy posts.![]()
I had exactly that. The water was coming out of the speaker that is above the pocket. I took the door skin off. Someone had cut the lower half of the vapor barrier off and thrown it away. I assume they did this to change out the window regulator. They had also forgot to tighten the airbag bolts (one was already missing) and some of the other screws. The only cure was to replace the barrier (and missing bolt).just to be clear: The inside pocket in the door panel is what is filling up with water and it is a lot of water, sometimes it is almost full after it has rained all night
