1 - 5 of 5 Posts
So i was wondering if 18 x 8.5 inch rims , front & back would fit my 2005 325i . Et 35 on all sides. Im upgrading from my stock 16***8221; . Any information would be helpful thanks.
2005 BMW 330i
Yes sir. You can run a 225/40R18 tire size and it'll fit nicely. Wheels will be nicely pushed out a little bit, but it'll make for a good, upgraded look. Not overly excessive or will run into issues.
Sent from my Pixel 3 XL using Tapatalk
Vendor
This fitment is actually our recommended direct bolt-on fitment for the non-M E46.
In addition to the 225s mentioned above, you can also run a 235/40-18 tire as a direct fit as well.
You can even step up to a 245/35-18 but you may need to run a spacer in the front if you are running coilovers.
-Tom
You can run 235/40's on the front and go a little wider in the rear like 245/40's with no problems. What wheels are you planning to get? I saw some nice options at 4wheelonline such as the Niche, American Racing, Foose and Helo.
328Ci
What about stock 255/35 in the rear. You're implying once you go as low as ET35 you can't run 255/35 without rolling fenders?
I've been looking at hundreds of wheel brands last two months and they all have a hard-on for 18x8.5 ET35 and no other offset for BMW. I'm not going to pay Rays $3K for the privilege to ruin my paint.
1 - 5 of 5 Posts
