1 - 6 of 6 Posts
Need help! Looming to get a set of 18" wheels. Front is 18x8.5 et 30 and rear are 18x9.5 et 25..will this setup work without any rubbing issues? Or what would be the correct offset with the above rim size..thanks
I just out 18" 8.5" et35, 9.5" et22 on mine today.
The front could be 5mm further out (et30) yet you'd have to run stretched tires for sure as et35 is flush.
The rear could be 10mm futher out (et12) so with et25 you'll be fine.
1 - 6 of 6 Posts
